[GRASSLIST:8880] RE: table of x, y and z points
Patton, Eric epatton at nrcan.gc.ca
Fri Nov 4 06:41:14 EST 2005
---------Original Message-----
Subject: Re: [GRASSLIST:8853] RE: table of x, y and z points
> Like you said I try the following:
> $v.in.ascii -z input=/home/tiago/teste output=teste_out format=point
fs=tab skip=1 columns='x double precision, y double precision, z double >
precision, cat int' \ x=1 y=2 z=3 cat=0
> with teste file like this:
x	y	z
1	1	1
2	2	2
3	3	3
4	4	2
5	5	1
GRASS just didn't made anything. Do you have some idea about what is wrong?
Tiago Salgueiro
Try typing
g.list vect
Do you see your output file 'teste_out'? If so, you will have to set your
region to that of your new vector:
g.region vect=teste_out
Then,
d.vect map=teste_out
as Hamish already mentioned. Incidentally, I tried entering the exact same
v.in.ascii commands you listed above, with the same xyz file and it worked
perfectly.
~ Eric.
