[GRASSLIST:8915] Re: db.select
Maik Trömel maik.troemel at maitro.net
Mon Nov 7 07:59:55 EST 2005
Ok, it works!
Thanks a lot!
Greetings from Germany
Jachym Cepicky wrote:
>the problem is, you are using the "pipe" character -- '|' which is used
>for unix pipdb.select table=vRegoins fs="|"ing -- you can send results from one program to another.
>    use simply
>db.select table=vRegions
>or
>instead
>jachym
>On Mon, Nov 07, 2005 at 10:53:43AM +0100, Maik Trömel wrote:
>>Hello,
>>how can I work with db.select over the console?
>>When I work with the GUI its no problem. But when I copy the instruction
>>(db.select table=vRegions database=$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/
>>driver=dbf fs=| ) to the console nothing happens. Whats going wrong? I
>>hope someone can help me.
>>Thanks a lot.
>>Greetings
>>Maik
