[GRASSLIST:8921] Re: points in area
    Maik Trömel
    maik.troemel at maitro.net
    Mon Nov  7 12:08:45 EST 2005
I thought of a faster solution ;-p
Are there any other statistic tools like r.univar. One which is able to
make a selection? Something like: "Make a statistik of all points lying
in area "a"!" (without extracting and selecting before)
Maik
Markus Neteler wrote:
>Maik,
>please define "better solution"...
>Markus
>On Mon, Nov 07, 2005 at 05:06:52PM +0100, Maik Trömel wrote:
>>I thought of this too. But I hoped there would be a better solution.
>>>Maik Trömel wrote:
>>>>I think my question is not clear enough.
>>>>I know there's possibility to get points lying in an area with v.select.
>>>>In my map i've got several areas. I need all points lying in area a to
>>>>make a statistic with v.univar. But with v.select there is only the
>>>>possibility to get all points lying in all areas. That's not what I need.
>>>Simply first extract area 'a' with v.extract, then run v.select on this
>>>new map.
>>>For several areas it's best to write a small script which loops over the
>>>area map,
>>>extracts, selects, and runs v.univer.
>>>hope this helps
>>>Markus
