[GRASSLIST:8927] statistic mode
ivan marchesini
marchesini at unipg.it
Tue Nov 8 02:39:27 EST 2005
dear users....
I have a problem regarding the aspect map...
I need to obtain the main orientation of some slopes...
if I use the r.univar module to obtain the everage of the cells values,
I obtain false results, because, for example:
a slope degrading towards est is full of cells having values comprised
between 0 and 45 and comprised between 315 and 360... the average is
probably ~180.... exactly the opposite value I was looking for....
so I have thougth that I need probably the mode of the distribution,
i.e. the value of the cells which are more present in the map....
do you know how I can simply obtain the mode???
do you have a better solution
ivan
Ivan Marchesini
Department of Civil and Environmental Engineering
University of Perugia
Via G. Duranti 93/a
06125
Perugia (Italy)
e-mail: marchesini at unipg.it
ivan.marchesini at gmail.com
tel: +39(0)755853760
fax: +39(0)755853756
