[GRASSLIST:8944] make a x, y, z map
Tiago Salgueiro 1010664 at isep.ipp.pt
Tue Nov 8 20:34:32 EST 2005
Hi all,
I've fedora 3 and grass60 installed.
With this text file called teste:
x	y	z
1	1	1
2	2	3
3	3	4
4	4	2
5	5	1
how can I make the correspondent map? I tried run grass but ask me to
create a location and I don't want to do that.
I just want to use the command :
>$ v.in.ascii -z input=/home/tiago/teste output=teste_out format=point
fs=tab skip=1 columns='x double precision, y double precision, z double >
precision, cat int' \ x=1 y=2 z=3 cat=0
Thanks!
_____________________
Cumprimentos/Best Regards,
Tiago Salgueiro
Nº1010664
