[GRASSLIST:8953] Re: make a x, y, z map
Tiago Salgueiro 1010664 at isep.ipp.pt
Wed Nov 9 07:59:01 EST 2005
Now I create a location, I hope is created well...
when I try the command:
v.in.ascii -z input=/home/tiago/teste output=teste_out format=point
fs=tab skip=1 columns='x double precision, y double precision, z double
precision, cat int' \x=1 y=2 z=3 cat=0
The message I had is the following:
v.in.ascii: error while loading shared libraries: libgdal.so.1: cannot
open shared object file: No such file or directory
How can I solve the problem??
_____________________
Cumprimentos/Best Regards,
Tiago Salgueiro
Nº1010664
> Tiago, I think you need to have a location to import your map into with
> v.in.ascii.  Otherwise, where is that map going to be imported?  Once
> you have a location set up, you can then import your text file.
> Hope this helps,
> Ian
> On Nov 8, 2005, at 5:34 PM, Tiago Salgueiro wrote:
>> Hi all,
>> I've fedora 3 and grass60 installed.
>> With this text file called teste:
>> x	y	z
>> 1	1	1
>> 2	2	3
>> 3	3	4
>> 4	4	2
>> 5	5	1
>> how can I make the correspondent map? I tried run grass but ask me to
>> create a location and I don't want to do that.
>> I just want to use the command :
>>> $ v.in.ascii -z input=/home/tiago/teste output=teste_out format=point
>> double >
>> precision, cat int' \ x=1 y=2 z=3 cat=0
>> Thanks!
>> Tiago Salgueiro
>> Nº1010664
> What happens if a big asteroid hits Earth? Judging from realistic
> simulations involving a sledge hammer and a common laboratory frog, we
> can assume it will be pretty bad.
>   - Dave Barry
> This message has been scanned by Postini anti-virus software.
