[GRASSLIST:8954] Re: freeze while digit
Phillip J. Allen paallen at attglobal.net
Wed Nov 9 08:07:29 EST 2005
Hello,
I am currently using grass61 under cygwin on a Dell Inspiron 9200
Centrino with 2G of memory and this is a very serious problem!
Trying to use i.points is painful and not worth the problems.  Waiting
for the redraw or the zoom/box to draw on the screen can take over 30-50
seconds.
So there is confirmation.  Hope this can be easily fixed.
Phillip J. Allen
David Finlayson wrote:
>I haven't used Cygwin for a while so my info may be dated.
>There are some routines in grass (d.zoom, d.where, etc) that pole the
>mouse and wait for user input to the monitor. I found that many of
>them overwhelmed Cygwin GRASS and froze the program. Sometimes if you
>complete the action (right-click usually) and wait, GRASS returns from
>the dead after a bit.
>This occurs to a lesser extent on the Linux version of GRASS. But even
>on linux, if you leave GRASS waiting for mouse input (say during a
>zoom operation) it will consume 100% cpu until you complete the mouse
>op.
>I think that this has been discussed in the past, but most developers
>are on Linux and may not be aware of how bad this behaves in Cygwin.
>Some kind of multi-threading issue (or lack of multi-threading I
>think).
>David
>On 11/8/05, Ralf Gerlich <ralf.gerlich at bsse.biz> wrote:
>>Hello,
>>Josip Vrlić wrote:
>>>Hello!
>>>I use Grass 6.1 with Cygwin (Windows xp) and while i'm in module
>>>v.digit, open monitor is often be freeze. And after I exit end enter
>>>again I lost everything I have been digitalize because I can't open
>>>cretaed map for continue digit with this message:
>>>Cannot open old vector mk11GraniceKopna at PERMANENT
>>><mailto:mk11GraniceKopna at PERMANENT> on level 2
>>>Does anyone know how to resolve this problem?
>>You need to run
>>v.build map=mk11GraniceKopna
>>in your PERMANENT mapset. On the general issue of v.digit freezing on
>>Cygwin: Sorry, I can't help. I'm having this problem myself.
>>Hope this helps,
>>Ralf
>David Finlayson
>Marine Geology & Geophysics
>School of Oceanography
>Box 357940
>University of Washington
>Seattle, WA  98195-7940
>USA
>Office: Marine Sciences Building, Room 112
>Phone: (206) 616-9407
>Web: http://students.washington.edu/dfinlays
