[GRASSLIST:8956] Re: make a x, y, z map
Stephan Holl holl at gdf-hannover.de
Wed Nov 9 08:52:37 EST 2005
Hello Tiago,
On Wed, 9 Nov 2005 12:59:01 -0000 (WET) "Tiago Salgueiro"
<1010664 at isep.ipp.pt> wrote:
> Now I create a location, I hope is created well...
> when I try the command:
> v.in.ascii -z input=/home/tiago/teste output=teste_out
> format=point fs=tab skip=1 columns='x double precision, y double
> precision, z double precision, cat int' \x=1 y=2 z=3 cat=0
> The message I had is the following:
> v.in.ascii: error while loading shared libraries: libgdal.so.1: cannot
> open shared object file: No such file or directory
> How can I solve the problem??
it looks like your installation of gdal is somewhat faulty. Please
check that libgdal.so.1 is existent on your filesystem and can be found
in one of the folders listed in /etc/ld.so.conf.
If the path to libgdal is not in there, add it and run ldconfig (as
root) afterwards.
 hope that helps
	Stephan
GDF Hannover - Solutions for spatial data analysis and remote sensing
Hannover Office      -     Mengendamm 16d      -     D-30177 Hannover
Internet: www.gdf-hannover.de      -      Email: holl at gdf-hannover.de
Phone : ++49-(0)511.39088507       -        Fax: ++49-(0)511.39088508
