[GRASSLIST:8977] Re: Some issue with v.in.ascii and GRASS manual
Luca Casagrande luca.casagrande at gmail.com
Thu Nov 10 08:15:53 EST 2005
Alle 12:52, giovedì 10 novembre 2005, Markus Neteler ha scritto:
> On Wed, Nov 09, 2005 at 04:39:21PM +0100, Luca Casagrande wrote:
> > Hi to all guys!
> > For my italian gis wiki ( http://www.freegis-wiki.it ) i am adding to the
> > FAQ section the question that i found on the international ML (the
> > italian one is not so populated ). I notice that a lot are having issue
> > with importing txt file as vector one, so i decided to do some resarch in
> > this direction. I toke this example from  v.in.ascii manual:
> > GRASS 6.0.1 (spearfish60):~ > cat points3d.dat
> > 593493.1|4914730.2|123.1|studna|well
> > 591950.2|4923000.5|222.3|kadibudka|closet
> > 589860.5|4922000.0|232.3|hruska|pear
> > 590400.5|4922820.8|143.2|mysi dira|mouse hole
> > 593549.3|4925500.7|442.6|mineralni pramen|mineral spring
> > 600375.7|4925235.6|342.2|kozi stezka|goat path
> > and then run:
> > cat points3d.dat | v.in.ascii -z z=3 cat=0 out=mypoints3D \
> >                    columns='x double, y double, z double, label_cz
> > varchar(20), label_en varchar(20)'
> > But got this output:
> > Maximum input row length: 25
> > Maximum number of columns: 3
> > Minimum number of columns: 0
> > ERROR: x column number > minimum last column number
> > What am i missing?
> Luca,
> are you using the sqlite driver (db.connect -p)?
> I tried, it fails for me with sqlite, apparently
> db_set_column_length() returns -1 for string columns/sqlite.
> With e.g. DBF driver it works. We'll have to fix this.
> Markus
Hi Markus and thx for your answer,
i am not yet an expert in db command (still focusing on other things...).
I just opened the spearfish PERMANENT dataset and did the command...
Hope to be usefull
Luca
gtalk: luca.casagrande at gmail.com
skype : thedoktor78
msn: doktoreas at hush.com
