[GRASSLIST:8982] Re: switching to postgres
Kirk R. Wythers kwythers at umn.edu
Thu Nov 10 12:26:27 EST 2005
On Oct 31, 2005, at 2:49 AM, Radim Blazek wrote:
> On 10/28/05, Stephan Holl <holl at gdf-hannover.de> wrote:
>> AFAIK the database needs to be created before. If you would just
>> copying your existing tables to PG, you should consider using db.copy
>> and reconnect the newly created tables in PG with your dataset (with
>> v.db.connect)
> Or
> g.copy vect=
> g.remove vect=
Hi Radim, which (db.copy or g.copy) do you recommend and why? I am
having trouble with db.copy (DBMI-DBF error).
Kirk
> Radim
