[GRASSLIST:8987] Re: v.in.ascii error
Tiago Salgueiro 1010664 at isep.ipp.pt
Thu Nov 10 15:50:50 EST 2005
I think it works because now I didn't got any error.
But I don't know how to see the map. I tryed g.region but I don't know
what to put in all fields... Can you help?
Thanks!
Tiago
> Try formatting the file like this:
> 1|1|1
> 2|2|3
> 3|3|1
> 4|4|2
> 5|5|3
> 6|6|4
> with | as the field delimiter, and in point rather than standard output
> format:
> v.in.ascii input=/home/salgueit/testar.txt output=testar1_out
> format=point fs=| skip=1 'columns=x double, y double, z double' x=1 y=2
> z=3 cat=0 -z
> If that works, view the map by setting the region to match the new
> vector file (use g.region), opening a diplay monitor and then using the
> command d.vect to display the new vector file.
> eva.
> Tiago Salgueiro wrote:
>> I give up to use grass with fedora core 3. Now I'm runing grass under
>> Windows Xp. And my problem now is the following:
>> with th file testar.txt:
>> x	y	z
>> 1	1	1
>> 2	2	3
>> 3	3	1
>> 4	4	2
>> 5	5	3
>> 6	6	4
>> AND THE COMMAND:
>> format=standard fs=tab skip=1 x=1 y=2 z=3 cat=0 -z
>> GRASS RETURNED:
>> Error reading ascii file:
>> 1	1	1
>> Building topology ...
>> Registering lines:
>> 0 primitives registered
>> Building areas:
>> 0 areas built
>> 0 isles built
>> Attaching islands:
>> Attaching centroids: Topology was built.
>> Number of nodes     :   0
>> Number of primitives:   0
>> Number of points    :   0
>> Number of lines     :   0
>> Number of boundaries:   0
>> Number of centroids :   0
>> Number of areas     :   0
>> Number of isles     :   0
>> Am I doing something wrong? After I have success with this how can I see
>> the map generated?
>> Thanks!
>> _____________________
>> Cumprimentos/Best Regards,
>> Tiago Salgueiro
>> Nº1010664
> Eva L. Hulse
> PhD Student
> University at Buffalo Anthropology Department
> evahulse at buffalo.edu
Tiago Salgueiro
Nº1010664
