[GRASSLIST:9000] Re: sqlite and v.rast.stats problem
Thu Nov 10 20:31:27 EST 2005
> The second problem is that this is horribly inefficient for my
> statistics problem. I have a huge DEM with lots of small blocks that I
> am generating statistics for. It takes several minutes for each
> calculation because the whole map is used for each call to r.univar.
> Is it possible to clip the null areas from the map region to speed up
> the calculation from r.univar?
Yes, save the region with g.region, extract the small block to a new map
with r.mapcalc, 'g.region zoom=' to the extent of the new data in
r.mapcalc, run r.univar, then restore the old region. Maybe about the
same processing time?
maybe [reclass and] use r.stats instead on the full map?
Hamish
