[GRASSLIST:9034] Re: 3D blocks again
Dylan Beaudette dylan at iici.no-ip.org
Sun Nov 13 12:53:33 EST 2005
Actually I meant to say: why not use GRASS->POVRAY
i.e. import your data into GRASS, manipulate it as you see fit. Then
export it to POVRAY with v.out.pov . You can then customize the output
to render cubes instead of points.
Dylan
On Nov 13, 2005, at 7:32 AM, Ing.Peter Misovic wrote:
> Hmm it sounds good, I hoped GRASS could help me but as I see I have to
> try another solutions :( Thank you.
> Peter
> On 11/12/05, Dylan Beaudette <debeaudette at ucdavis.edu> wrote:
>> On Nov 12, 2005, at 12:37 PM, Ing.Peter Misovic wrote:
>>> Dear all,
>>> we're back after 2 weeks of everyday effort with displaying primitive
>>> 3D geometry - cube. We tried to use many solutions (ASCII, POSTGIS,
>>> POSTGRES, GML ...) but with no effect. As I (and my friend Peter)
>>> already wrote, our only need is to display cubes. Anyhow. Our last
>>> try
>>> was with GML files. But independently of input formats the result is
>>> we are not able to display vertical multipolygons or areas. Only
>>> horizontal objects (multipolygons and area) or line model with no
>>> fills. Please, this is probably our last ask for help : How would be
>>> able to do that ?
>>> Thank you all,
>>> Peter Misovic
>>> Peter Sasvari
>> how about POVRAY ?
>> Dylan Beaudette
>> Soils and Biogeochemistry Graduate Group
>> University of California at Davis
>> 530.754.7341
Dylan Beaudette
530.754.7341
