[GRASSLIST:9036] Re: 3D blocks again
Ing.Peter Misovic peter.misovic at gmail.com
Sun Nov 13 13:41:11 EST 2005
On 11/13/05, Dylan Beaudette <dylan at iici.no-ip.org> wrote:
> Actually I meant to say: why not use GRASS->POVRAY
> i.e. import your data into GRASS, manipulate it as you see fit. Then
> export it to POVRAY with v.out.pov . You can then customize the output
> to render cubes instead of points.
> Dylan
> On Nov 13, 2005, at 7:32 AM, Ing.Peter Misovic wrote:
> > Hmm it sounds good, I hoped GRASS could help me but as I see I have to
> > try another solutions :( Thank you.
> > Peter
> > On 11/12/05, Dylan Beaudette <debeaudette at ucdavis.edu> wrote:
> >> On Nov 12, 2005, at 12:37 PM, Ing.Peter Misovic wrote:
> >>> Dear all,
> >>> we're back after 2 weeks of everyday effort with displaying primitive
> >>> 3D geometry - cube. We tried to use many solutions (ASCII, POSTGIS,
> >>> POSTGRES, GML ...) but with no effect. As I (and my friend Peter)
> >>> already wrote, our only need is to display cubes. Anyhow. Our last
> >>> try
> >>> was with GML files. But independently of input formats the result is
> >>> we are not able to display vertical multipolygons or areas. Only
> >>> horizontal objects (multipolygons and area) or line model with no
> >>> fills. Please, this is probably our last ask for help : How would be
> >>> able to do that ?
> >>> Thank you all,
> >>> Peter Misovic
> >>> Peter Sasvari
> >> how about POVRAY ?
> >> Dylan Beaudette
> >> Soils and Biogeochemistry Graduate Group
> >> University of California at Davis
> >> 530.754.7341
> Dylan Beaudette
> 530.754.7341
