[GRASSLIST:9048] Re: 3D blocks again
Ing.Peter Misovic peter.misovic at gmail.com
Mon Nov 14 04:50:09 EST 2005
Hi Dylan,
In fact I have 3D matrix of points. Nature of data source is table in
postgres/Postgis with columns : x, y, z, the_geom (for 3d point) etc.
X,Y,Z are coordinates of centroid. I need display those centriods like
cubes (or it's better to say cuboids, blocks, not cube) with specific
colour. If it is possible in PovRay do I have to use grass ? Or Did
you mean to use GRASS for generate cubes and there export it into
POVRAY ? Or how did you mean it ?
Thank you very much for your time and effort you spent with this problem.
Peter
On 11/13/05, Dylan Beaudette <dylan at iici.no-ip.org> wrote:
> On Nov 13, 2005, at 10:38 AM, Ing.Peter Misovic wrote:
> > HI Dylan,
> > Ok now I have understood what you ment but maybe I could summary our
> > problem again :
> > -we would like to server data as following :
> > POSTGIS -> mapserver for 2D (in future Open3DGIS)
> > POSTGIS (postgres) -> GRASS for 3D (Open3DGIS is not ready with boxes
> > now - planned for 0.2)
> > -Problem : we are not able corretly display box (cube) in NVIZ. We
> > tried to use GML,POSTGRES,ASCII, 3D shp from ArcView ... instead of
> > POSTGIS. But with no positive effect. Data are not showed correctly
> > f.e (no vertical polygons or areas, missing lines etc.).
> Hmmm. I was under the (false?) impression that you had a 3D matrix of
> points, that needed to be displayed as cubes. What is the nature of
> your input data source? The suggestion to use GRASS--->POVRAY was based
> on the assumption that you had 3D point data.
> If this is not that case, perhaps something like OpenDX would work?
> Cheers,
> Dylan Beaudette
> Soils and Biogeochemistry Graduate Group
> University of California at Davis
> 530.754.7341
