[GRASSLIST:9055] v.net.path
Aldo Clerici alcl01 at ipruniv.cce.unipr.it
Mon Nov 14 10:13:05 EST 2005
Dear GRASSusers,
I'm not able to run v.net.path with more than a couple of points.
The command:
echo "1 592634 4925356 596568 4922912" | v.net.path in=roads ou=roads_pt
works properly, but
echo "1 592634 4925356 596568 4922912 2 591738 4923061 593170 4915608" |
gives the error "Wrong input format"
What's the right way to put more points in the command?
Many thanks
Aldo Clerici
PS: The form:
v.net.path in=roads ou=roads_pt <<end
> end
works very well.
