[GRASSLIST:9065] Re: GRASS 6 in a nutshell tutorial
Luigi Ponti lponti at infinito.it
Mon Nov 14 17:06:47 EST 2005
Thanks Amish,
looking at v.info and r.info, it seems the two maps have the same
projection (see below). However, when looking at the output "d.where -w"
for a sample map point (the San Francisco Bay), the longitude is very
different in the two maps:
                                                   WGS84 Co-ordinates
             EAST:             NORTH:               LON:
   -191114.6346037    -24240.66895625  143:03:58.588289W   29:24:27.1
(San Francisco Bay on the California State vector layer - WRONG)
  1839139.30311877    663981.00484798  122:19:50.783112W   37:57:48.1
(San Francisco Bay on the Elevation Model raster layer - CORRECT)
Do you think this could be due to an error in the import process or
should I just look for another vector map?
Thanks again,
Luigi
v.info map=state layer=1
 | Layer:    state
Organization:                     |
 | Mapset:   luigi                          Source
Date:                      |
creator:                  |
 | Database:
/home/andy                                                       |
Title:        |
 | Map Scale:
1:1                                                            |
 | Map format:
native                                                         |
 |   Type of Map:  Vector (level:
2)                                          |
 |   Number of points:       0               Number of areas:
51         |
 |   Number of lines:        0               Number of islands:
48         |
 |   Number of boundaries:   59              Number of faces:
0          |
 |   Number of centroids:    51              Number of kernels:
0          |
 |   Map is 3D:
0                                                |
 |   Number of dblinks:
1                                                |
 |   Projection: Lambert Conformal Conic (zone
0)                             |
 |            N: 922206.900    S:
-701781.905                                 |
 |            E: 1043412.917     W:
-374425.808                               |
 |            B: 0.000         T:
0.000                                       |
 |   Digitize threshold:
0.00000                                              |
Comments:        |
r.info map=e10g at PERMANENT
 | Layer:    e10g                           Date: Tue Nov  8 17:25:24
2005    |
 | Mapset:   PERMANENT                      Login of Creator:
andy            |
Cal_nad83-zone3                                                  |
 | DataBase:
/home/andy                                                       |
 | Title:     ( e10g
 |   Type of Map:  raster              Number of Categories:
5443             |
 |   Data Type:
CELL                                                       |
 |   Rows:
7192                                                       |
 |   Columns:
11628                                                      |
 |   Total Cells:
83628576                                                   |
0)                        |
 |            N:    3353466    S:   -3838238   Res:
999.95884316              |
 |            E:    6073284    W:   -5555183   Res:
1000.04016168             |
 |   Range of data:    min =  -84 max =
5443                                  |
 |   Data
Source:                                                             |
 |   Data
Description:                                                        |
 |    generated by
r.proj                                                     |
Hamish wrote:
>>I have imported both the vector and the raster with minimum trouble,
>>since the first has a .prj file which GRASS recognized, and the second
>>had a detailed import tutorial in the cygwin-GRASS install page.
>>However, despite the fact the the two layers supposedly have the same
>>NAD83 projection info (I did not enter anything manually), when I try
>>to  display them together on a GRASS monitor, the state layout is in
>>the  middle of the ocean compared to the elevation raster.
>>Is there a way to overlap the two layers or to chek for a coordinate
>>error?
>r.info and v.info will give you the map extents, you should then be able
>to figure out which is correct.
>Also try "d.where -w" to give you a lat/lon value for different parts of
>your map which you can compare to the map on the wall.
>Hamish
