[GRASSLIST:9132] Re: v.transform
Ian MacMillan
ian_macmillan at umail.ucsb.edu
Fri Nov 18 00:31:18 EST 2005
I am not sure, but you might need to importthe file into grass first
using v.in.asii. Alternatively you can use the cs2cs tool that comes
with proj if you want to do this in a single step.
-Ian
On Nov 17, 2005, at 9:12 PM, Armando Scalise wrote:
> I got stuck trying to use v.transform.
> I keep getting the follwoing error: "Could not open file with
> coordinates : comorgpc2"
> The GCP file is in the PERMANENT mpaset in my current location. It was
> created with a text Editor, it contains 4 columns with coordiantes.
> I tried renaming it and using different file extensions, but nothing of
> what I have tried so far works.
> Any clue to help me solve this problem?
> Thanks
> Armando Scalise
> GeoInference
> Patagonia Argentina
> armando at geoinference.com
> armandoh at gmail.com
What happens if a big asteroid hits Earth? Judging from realistic
simulations involving a sledge hammer and a common laboratory frog, we
can assume it will be pretty bad.
- Dave Barry
This message has been scanned by Postini anti-virus software.
Name: not available
Type: text/enriched
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20051117/16a1fcc7/attachment.bin
