[GRASSLIST:9116] Re: Create new location with shellscript
Paul Kelly
paul-grass at stjohnspoint.co.uk
Thu Nov 17 05:29:51 EST 2005
Hello all
On Thu, 17 Nov 2005, Hamish wrote:
>> is there a documentation about the parameters necessary for the
>> diffrent projections known in GRASS.
> Generally it follows PROJ4 parameters:
> http://www.remotesensing.org/proj/
> http://www.remotesensing.org/proj/gen_parms.html
Something Frank said on the PROJ list recently kind of hinted that there
might be some new programmatic way of finding out about the parameters
needed for different projections:
http://lists.maptools.org/pipermail/proj/2005-November/001876.html
But I haven't had time to investigate it.
> Usually you just need to run g.setproj and type "list" if you don't
> know what to choose. see also g.proj.
Yes g.setproj is interactive only so can't be used from a shell script.
g.proj has become quite versatile in creating new locations from various
sources of projection information; have you looked through the examples in
the g.proj man page?
Paul
