[GRASSLIST:9182] Re: [Fwd: Re: GRASS 6 in a nutshell tutorial]
Stephan Holl
holl at gdf-hannover.de
Tue Nov 22 02:53:06 EST 2005
Hello Luigi,
On Mon, 21 Nov 2005 17:20:05 -0800 Luigi Ponti <lponti at infinito.it>
wrote:
> Thanks Ian and Hamish,
> I was eventually able to fix the problem by downloading a unprojected
> California layout shapefile (form <www.census.gov>) and then
> importing it via v.proj in the location with the digital elevation
> map. Apparently the official shapefile of California layout has a
> wrong latitude.
> Next step is to connect the output table of the population model
> (population densities at weather stations) to the map I have just
> created. This would hopefully result in an interpolated raster.
> Hamish suggested the following:
> Load in site data with v.in.ascii & interpolate between sites with
> v.surf.rst.
> According to the manual v.in.ascii uses the | separator. Is it worth
> to manually put the file in that format or do you think is better to
> convert it in a database to connect with a specific command?
you could use the fs="," for selecting a , as a selector.
have a look at the manual-page of v.in.ascii.
g.manual v.in.ascii or
v.in.ascii -h
Best
Stephan
GDF Hannover - Solutions for spatial data analysis and remote sensing
Hannover Office - Mengendamm 16d - D-30177 Hannover
Internet: www.gdf-hannover.de - Email: holl at gdf-hannover.de
Phone : ++49-(0)511.39088507 - Fax: ++49-(0)511.39088508
