[GRASSLIST:9199] Re: XY to Projection
Maciek Sieczka werchowyna at epf.pl
Wed Nov 23 07:33:37 EST 2005
Ok, so you have your unprojected vector layer digitised from an
unprojected raster map.
To project both now:
1. Project your raster map in Grass first.
2. Export the unprojected vector to a shapefile and import to the
destination location, where the background . It won't fit to your
projected raster - of couerse
In the "group" directory of you source location there is a file which
stores points you marked with i.poins when calibarting raster.
3.
  Dive into your grassdata/caves_xy/wlasnosc/group/wlasnosc
Use the same coordinates for
On śro, 2005-11-23 at 04:09 -0800, RAVI KUMAR wrote:
> Hi,
> V.Transform cannot transform an XY location to
> a Projected Location, say WGS-84.
> However if it is a projected location.. then V.Transform can Change to
> another projection.
> So if a beginer
> 1. Scans a map
> 2. Spends days painstakingly to vectorise it..
> And then it dawns upon him, that it must be projected..
> HE HAD IT..
> Developers please clear this lacuna.
> ThanQ
> Ravi Kumar
> ______________________________________________________________________
> Yahoo! FareChase - Search multiple travel sites in one click.
W polskim Internecie są setki milionów stron. My przekazujemy Tobie tylko najlepsze z nich!
http://katalog.epf.pl/
