[GRASSLIST:9233] Re: mapping the output of a population model
Ian MacMillan ian_macmillan at umail.ucsb.edu
Mon Nov 28 17:40:53 EST 2005
Luigi, try something like:
r.mapcalc newmap= 'if (oldmap>1000,oldmap,null())'
-Ian
On Nov 28, 2005, at 1:48 PM, Luigi Ponti wrote:
> Thanks Stephan,
> I was able to import the ASCII text file to vector points and
> interpolate between them.
> Also, based on a very useful but unrelated discussion, I obtained a
> very pretty shaded relief over which I draped the interpolated raster.
> Now I have started clipping the region that are not of interest to the
> analysis. To clip out what is not California, I have transformed a
> vector layout of the state to a raster via v.to.rast, and used it as a
> mask in v.surf.rst.
> How could I clip regions that have an elevation greater than a
> particular value based on the elevation model raster?
> Thanks again,
> Luigi
> Stephan Holl wrote:
>> Hello Luigi,
>> On Mon, 21 Nov 2005 17:20:05 -0800 Luigi Ponti <lponti at infinito.it>
>> wrote:
>>> Thanks Ian and Hamish,
>>> I was eventually able to fix the problem by downloading a
>>> unprojected California layout shapefile (form <www.census.gov>) and
>>> then
>>> importing it via v.proj in the location with the digital elevation
>>> map. Apparently the official shapefile of California layout has a
>>> wrong latitude.
>>> Next step is to connect the output table of the population model
>>> (population densities at weather stations) to the map I have just
>>> created. This would hopefully result in an interpolated raster.
>>> Hamish suggested the following:
>>> Load in site data with v.in.ascii & interpolate between sites with
>>> v.surf.rst.
>>> According to the manual v.in.ascii uses the | separator. Is it worth
>>> to manually put the file in that format or do you think is better to
>>> convert it in a database to connect with a specific command?
>> you could use the fs="," for selecting a , as a selector.
>> have a look at the manual-page of v.in.ascii.
>> g.manual v.in.ascii or
>> v.in.ascii -h
>> Best
>> 	Stephan
What happens if a big asteroid hits Earth? Judging from realistic
simulations involving a sledge hammer and a common laboratory frog, we
can assume it will be pretty bad.
  - Dave Barry
This message has been scanned by Postini anti-virus software.
