[GRASSLIST:9238] d.vect gives error
orkun temiz at deprem.gov.tr
Tue Nov 29 04:18:16 EST 2005
Hello
I found neccessary command to generate contours from DEM.
But after generating contours using r.contours. d.vect gives:
GRASS_INFO_WARNING(10978,1): coor files of vector 'elv2_cont3 at orkun' is
larger than it should be (14 bytes excess).
what can I do ?
regards
Ahmet Temiz
______________________________________
XamimeLT - installed on mailserver for domain @deprem.gov.tr
Queries to: postmaster at deprem.gov.tr
The views and opinions expressed in this e-mail message are the sender's own
and do not necessarily represent the views and the opinions of Earthquake Research Dept.
of General Directorate of Disaster Affairs.
Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
