[GRASSLIST:9241] Re: d.vect gives error
orkun temiz at deprem.gov.tr
Tue Nov 29 08:11:52 EST 2005
Jachym Cepicky wrote:
>try
>v.build elev2_cont
>what does it write?
>jachym
>On Tue, Nov 29, 2005 at 11:18:16AM +0200, orkun wrote:
>>Hello
>>I found neccessary command to generate contours from DEM.
>>But after generating contours using r.contours. d.vect gives:
>>GRASS_INFO_WARNING(10978,1): coor files of vector 'elv2_cont3 at orkun' is
>>larger than it should be (14 bytes excess).
>>what can I do ?
>>regards
>>Ahmet Temiz
>>______________________________________
>>XamimeLT - installed on mailserver for domain @deprem.gov.tr
>>Queries to: postmaster at deprem.gov.tr
>>The views and opinions expressed in this e-mail message are the sender's own
>>and do not necessarily represent the views and the opinions of Earthquake
>>Research Dept.
>>of General Directorate of Disaster Affairs.
>>Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak
>>T.C.
>>B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte
>>degildir.
thank you
v.build map=elv2_cont3 option=build
GRASS_INFO_WARNING(13283,1): coor files of vector 'elv2_cont3 at orkun' is
regards
and do not necessarily represent the views and the opinions of Earthquake Research Dept.
Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
