[GRASSLIST:8468] AW: Re: Importing Raster-Data
Maik Trömel maik.troemel at maitro.net
Mon Oct 3 07:49:41 EDT 2005
> If that doesn't work, I would give r.in.ascii a try.  You will have to
> play around with the parameters there to get it to work.
I tried out with r.in.ascii:
r.in.ascii input=/testwnd.dat output=test3421 'mult=1.0 or read from header'
'nv=-9999 or read from header'
I got an error:
GRASS_INFO_ERROR(7780,1): data conversion failed at row 1046, col 673
I checked the file at row 1046, col 673. But there is no reason for an
error. Any idea what the problem could be?
> -Ian
> On Sep 26, 2005, at 8:56 AM, Stephan Holl wrote:
> > Hello Maik,
> > On Mon, 26 Sep 2005 17:43:45 +0200 Maik Trömel
> > <maik.troemel at maitro.net> wrote:
> >> How can I import the Data?
> >> All methods I tried out didn`t work.
> > Which methods?
> > AFAIK your data looks like Esris ARC INFO ASCII grids. (r.in.arc)
> > Best
> >   Stephan
> This message has been scanned by Postini anti-virus software.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20051003/fe900ee1/attachment.html
