[GRASSLIST:8625] Re: Mandriva LE2005 : NVIZ error
Ing.Peter Misovic peter.misovic at gmail.com
Fri Oct 14 07:21:29 EDT 2005
Hi Markus,
problem is that NVIZ is not running. Only those messages are displayed
and that's all. :( But as I wrote, I installed newer libMesa packages
and everything is OK now. The most interesting for me is that 6.0.1RC2
was running with any problem. Was GRASS built on newer versions ?
Anyway, thank you for your response.
On 10/13/05, Markus Neteler <neteler at itc.it> wrote:
> On Sun, Oct 09, 2005 at 02:48:05AM +0200, Ing.Peter Misovic wrote:
> > Dear all,
> > I've installed grass6.0.1. If I try to start NVIZ, following error will raise :
> > Loading required GL library /usr/X11R6/lib/libGL.so.1.2
> > libGL warning: 3D driver claims to not support visual 0x24
> > libGL warning: 3D driver claims to not support visual 0x28
> > libGL warning: 3D driver claims to not support visual 0x2c
> > libGL warning: 3D driver claims to not support visual 0x30
> > Please, what to do now ?
> > Thank you
> Peter,
> I don't know if anyone answered, but you can simply ignore
> it (AFAIK). It's just a warning, I have it, too.
> Markus
