[GRASSLIST:8644] Re: Problems with Installing Grass 6.1 CVS
Sat Oct 15 12:23:22 EDT 2005
Tim Semmelhaack wrote:
> I tried to install 6.1 from the current CVS Snapshot and got the message:
> "error while loading shared libraries: libpq.so.4: cannot open shared
> object file: No such file or directory"
> Where is GRass looking for the libpq.so.4?
GRASS doesn't look for it; the loader (e.g. ld-linux.so.2) looks for
it, according to the contents of /etc/ld.so.cache (generated by
ldconfig by scanning the directories in /etc/ld.so.conf plus /lib and
/usr/lib) and the value of the environment variable LD_LIBRARY_PATH.
