[GRASSLIST:8648] Re: Warning in i.rectify
Sun Oct 16 18:58:43 EDT 2005
On Fri, 14 Oct 2005 10:41:23 +0200
Josip Vrliæ <josip.vrlic at plovput.hr> wrote:
> Hello!
> When I start i.rectify i get this error: "G_set_window(): Illegal latitude for North"
> Analyze in i.points is in attach.
> Can anyone know reason for this warning??
LOCATION: mk12                 GROUP: map                  MAPSET: PERMANENT
               Analysis of control point registration
        error                      image              target
  #   col   row  target       east     north      east     north
  1      not used             203.3    1377.9  502575.6 4889489.7
  2      not used             627.3    1479.0  504452.9 4889940.4
  3      not used            1495.6    2921.8  508293.6 4896353.8
  4      not used            2437.4    1932.3  512411.3 4891919.2
  5      not used            3460.9     806.8  517014.0 4887008.4
  6      not used            1547.2     667.5  508476.9 4886392.9
  7   2.1  -1.5   11.1        203.9    1377.3  502948.8 4889490.0
  8   3.2  -3.8   21.8        626.9    1481.0  504825.9 4889940.5
  9   2.1   4.6   22.7       1494.5    2924.8  508666.4 4896354.5
 10  -9.6  -9.1   58.3       2438.2    1931.8  512784.3 4891920.0
 11   7.2   1.1   32.6       3463.1     806.8  517387.3 4887009.5
 12  -6.1   6.2   38.3       1546.8     665.5  508850.2 4886393.5
 13   1.1   2.4   11.7       1821.8    2714.8  510108.5 4895420.5
Overall rms error: 32.04
Are you are using a lat-lon location for your import image when you
should use a simple XY location?
The northing in a lat-lon location can not be greater than 90N; and
image north above goes up to 3464.9 degrees N.
Hamish
