[GRASSLIST:8657] Re: connecting points with lines
Mon Oct 17 06:52:33 EDT 2005
> I think this is an easy question, but I can't seem to readily find
> the answer in the documentation.  Is there a simple way to connect
> lines (create topology) in a rater point layer?  Say, for example, a
> vector layer with two points, A and B.  Is there a simple way to have
> GRASS connect the two with a line from A to B?  Displaying this
> vector layer would then show a line, rather than just the two
> points.  I need to do this from the command line, as it is part of a
> script.
r.in.poly
Hamish
