[GRASSLIST:8685] Re: update grass6
Markus Neteler neteler at itc.it
Wed Oct 19 03:01:19 EDT 2005
Hamish wrote:
>>Exposing my problem : i must rear a map multilayers in Grass,for
>>strength dial i must do does the stop at edict v.db.addtable.
>>In the version by myself install , Debian , this command not it is
>>present ,
>>in order to make available it,i must update the  package containing
>>does the command?
>It is new and not in GRASS 6.0. But v.db.addtable only does this:
>echo "CREATE TABLE $table ($GIS_OPT_columns)" | db.execute
>You you can just type that at the command prompt.
>see the db.execute help page for usage examples.
>  http://grass.ibiblio.org/grass61/manuals/html61_user/db.execute.html
No, the script does a couple of extra things:
- generates the table
- add categories
- links the table to the map
- operates also on other layers than default layer=1
You can grab it from CVS:
 http://freegis.org/cgi-bin/viewcvs.cgi/grass6/scripts/v.db.addtable/
Markus
