[GRASSLIST:8713] Re: [GRASS5] Re: GIS Manager updates
Markus Neteler
neteler at itc.it
Thu Oct 20 07:44:55 EDT 2005
Hamish wrote:
>dumb solution to remove a column, but it should work:
>db.copy select=
>only those columns you want to keep. (parse `db.describe -c` in a script)
>Then remove old table, rename new table, and reconnect.
>(v.db.droptable, v.db.connect; v.dbselect, ?)
>This could be written as a script, eg v.db.delcol
> (v.db.rmcol, v.db.removecol, v.db.dropcol,...)
>but again, a fairly cruddy solution. Is there a SQL command that could
>be passed to db.execute?
>Hamish
Kirk R. Wythers wrote:
> On Oct 18, 2005, at 6:22 PM, Hamish wrote:
> postgres uses something like this:
> ALTER TABLE products ADD COLUMN description text;
> ALTER TABLE products DROP COLUMN description;
Maybe such a (needed) script has to distinguish between DBF driver and the
other real SQL drivers?
If connection == dbf then do_the_nasty_way
else
use the ALTER command
? To implement DROP column into the DBF driver might be hard.
Markus
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20051020/0a2d728e/attachment.html
