[GRASSLIST:8739] Re: GRASS 15th October CVS Bugs
Michael Barton michael.barton at asu.edu
Sun Oct 23 02:49:05 EDT 2005
Ravi,
It sounds like this is a d.rast problem and not a TclTk problem. I don¹t
have a version of GRASS 6.1 later than 15 October on my PowerBook at home.
But we have a 20 October version on the Fedora Core 4 Linux workstation in
my lab and d.rast works fine. I don¹t know much about the C modules, so it
is better if you report it to the general list
You need to report the error you have with d.rast in detail. You can use the
bug report web page if you¹d like.
List the terminal output results from d.rast. Also describe the platform you
are working on (OS, hardware, etc.).
With respect to the new features of the GIS Manager, look at the help page
(under the help menu). I recently updated it to cover the current functions
of the GIS Manager. I hope this is helpful. Let me know if you run into a
specific question about it.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
Arizona State University
Tempe, AZ 85287-2402
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
Date: Sat, 22 Oct 2005 23:21:03 -0700 (PDT)
To: Michael Barton <michael.barton at asu.edu>, <grasslist at baylor.edu>
Subject: Re: [GRASSLIST:8733] Re: GRASS 15th October CVS Bugs
the TclTk bug is not found in the earlier GRASS6.1 CVS (older than 15th
Oct).
Iam just using Elevation.dem of Spearfish data for a display.
d.rast doesnt work.. gives error
even in the D.M it gives the same error, when I try to displa raster.
I have used the latest D.M with the older GRASS6.1 (older than 15th Oct)
It works, BUT.. NVIZ is not understood..
Please give some help about various new itmems.
The button created for attribute information, is welcome.
This will be of great use, if it can help in choosing attributes in query,
istead of the user typing
the attribute names.
ThanX
Ravi Kumar
Michael Barton <michael.barton at asu.edu> wrote:
> I have only tested the new GIS Manager (i.e., from cvs or my website) with
> GRASS 6.1. However, it should work with 6.0.1 except for new commands or
> command options that are not available in the older release.
> The commands in the raster display panel include d.rast, d.legend, and d.his.
> All are present in 6.0.1 and haven¹t changed since that release.
> Are you doing a simple raster display (no draping or legend)? Does it work if
> you start d.rast from the command line and try to display the map? If you look
> at the TclTk error, it usually does give useful information, just a bit hard
> to find in the long error output (the most useful info is usually near the top
> of the error description).
> Michael
> phone: 480-965-6213
> fax: 480-965-7671
> From: RAVI KUMAR <ravivundavalli at yahoo.com>
> Date: Fri, 21 Oct 2005 00:14:19 -0700 (PDT)
> To: <grasslist at baylor.edu>
> Subject: [GRASSLIST:8727] GRASS 15th October CVS Bugs
> Hi All,
> 1. I have loaded GRASS6.0.1 from CVS.
> 2. I have also loaded the latest DM removing the old one
> BUT
> Unable to display raster 'elevation.dem' of spearfish data.
> ERROR= Error in Tcl Script
>                Error: Child killed : Segmentation Violation
> Please give details of latest DM and its function, or a web page link.
> Hope it will soon be integrated with the next week's GRASS CVS.
> ThanX
> Ravi Kumar
> Yahoo! FareChase - Search multiple travel sites in one click.
> <http://us.lrd.yahoo.com/_ylc=X3oDMTFqODRtdXQ4BF9TAzMyOTc1MDIEX3MDOTY2ODgxNjkE
> cG9zAzEEc2VjA21haWwtZm9vdGVyBHNsawNmYw--/SIG=110oav78o/**http%3a//farechase.ya
> hoo.com/>
kEcG9zAzEEc2VjA21haWwtZm9vdGVyBHNsawNmYw--/SIG=110oav78o/**http%3a//farechas
e.yahoo.com/>
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20051022/22bba749/attachment.html
