[GRASSLIST:8816] 61cvs: nviz doesn't start
ivan marchesini marchesini at unipg.it
Sun Oct 30 11:57:38 EST 2005
Dear developers,
I'm working on a debian testing and a i386 pc.
I have compiled the last grass61 CVS snapshot using these options:
___________________________________________________________________
CFLAGS="-g -Wall" ./configure --with-tcltk-includes=/usr/include/tcl8.3
--with-postgres-includes=/usr/include/postgresql --with-nls --with-glw
--with-glw-include=/usr/X11R6/include/GL --with-motif --with-sqlite
--with-freetype-includes=/usr/include/freetype2 --with-freetype
--with-cxx --enable-largefile
the result is this one:
C compiler:                  gcc -g -Wall
 C++ compiler:                c++ -g -O2
 FORTRAN compiler:
 Building shared libraries:   yes
 64bit support:               no
  NVIZ:                       yes
  X11 support:                yes
  JPEG support:               yes
  TIFF support:               yes
  PNG support:                yes
  Tcl/Tk support:             yes
  PostgreSQL support:         yes
  MySQL support:              no
  SQLite support:             yes
  OpenGL(R) support:          yes
  ODBC support:               no
  FFTW support:               yes
  BLAS support:               no
  LAPACK support:             no
  Motif support:              yes
  FreeType support:           yes
  GLw support:                yes
  NLS support:                yes
  Readline support:           no
  C++ support:                yes
  openDWG support:            no
  GDAL support:               yes
  OGR support:                yes
  Large File Support (LFS):   yes
The problem is that when I try to launch nviz I only obtain this result:
GRASS 6.1.cvs (lat_long_arg):~ > nviz
Abortito
I can't understand which is the problem!!
I have tried to compile only the nviz module (as described into the
INSTALL file), but anything have changed..
can you give me some ideas to solve the problem???
is a problem due to the CVS or is a problem of mine??
thank you very much
Ivan
Ivan Marchesini
Department of Civil and Environmental Engineering
University of Perugia
Via G. Duranti 93/a
06125
Perugia (Italy)
e-mail: marchesini at unipg.it
        ivan.marchesini at gmail.com
tel: +39(0)755853760
fax: +39(0)755853756
