[GRASSLIST:8163] Re: lon/lat to utm ?
Ian MacMillan ian_macmillan at umail.ucsb.edu
Fri Sep 2 10:32:37 EDT 2005
Ahmet, use v.in.region to create a box in your latlong location of your
current region.  Open up a utm location, and v.proj in that box.  Then
use v.info for information about the box that you just projected.
There may be an easier solution, but this one will work at least.
G'luck
-Ian
On Sep 1, 2005, at 11:49 PM, orkun wrote:
> hello
> my map region is in lon/lat projection.
> how can I get utm values of this  region  ?
> regards
> Ahmet Temiz
> ______________________________________
> XamimeLT - installed on mailserver for domain @deprem.gov.tr
> Queries to: postmaster at deprem.gov.tr
> The views and opinions expressed in this e-mail message are the
> sender's own
> and do not necessarily represent the views and the opinions of
> Earthquake Research Dept.
> of General Directorate of Disaster Affairs.
> Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal
> olarak T.C.
> B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici
> nitelikte degildir.
What happens if a big asteroid hits Earth? Judging from realistic
simulations involving a sledge hammer and a common laboratory frog, we
can assume it will be pretty bad.
  - Dave Barry
This message has been scanned by anti-virus software.
