[GRASSLIST:8190] Correction
Trevor Wiens twiens at interbaun.com
Tue Sep 6 18:51:17 EDT 2005
I posted v.sample.buffer on the GRASS wiki some time ago.
I discovered a bug in the mode calculation on line 153 of the script file
it should read
countlist[x]=`grep -c -e $val$ cells`
I will post a corrected version of the script on the next day or two on the wiki. For anyone who is using it please correct or you will not get correct mode values.
T
Trevor Wiens
The greatest obstacle to discovery is not ignorance - it is the illusion of knowledge.
(Daniel J. Boorstin)
