[GRASSLIST:8197] Re: Grass6.0.1 Binaries for Mandrake 10.0
Alejandro Hinojosa alhinc at cicese.mx
Wed Sep 7 12:07:43 EDT 2005
  Answering Otto an Michelle,
I didn't force any of the package installation with the -f switch, actually
there were only two fixes. The dependencies that had to be resolved are
gdal-1.3.0-2mdk10.1.i586.rpm  asked for libstdc++.so.6
and
grass-6.0.1-2mdk10.1.i586.rpm  asked for libfftw.so.2
and regarding Michelle's comment that this is not a grass issue,
unfortunately to get grass running you need to know something about make,
rpm (or equivalent),shell scripts, root privilegdes  and package
installation, at least it helped me get it running. I hope I didn't mess
something else.
Alejandro
At 08:26 AM 9/7/2005 +0200, you wrote:
>Am Dienstag, 6. September 2005 23:33 schrieb Alejandro Hinojosa:
> > Dear list,
>Dear Alejandro,
> > Since nobody came to the rescue but Otto , let me tell you how i fixed
> > using the binary distribution  intended for Mandrake 10.1 in version 10.0
> > This is to solve the dependencies of the distribution rpms. Otto indirectly
> > suggested to migrate to 10.1, but sometimes it's to much hassle to
> > backup  everything before migrating.
>Do you remember, what packages you had to upgrade on your mandrake 10.0. I
>could add your information to the readme - for other users.
> > I followed the installation sequence defined in the  readme of the
> > distribution site for Mandrake
> > http://www.gdf-hannover.de/media.php?id=1&lg=en
> > then when the dependencies started to appear i went
> > to  http://rpm.pbone.net  and searched for the libraries requested,
> > download them and installed manually with root privileges with  rpm
> > -ivh  package.rpm.
> > At the end, I got grass60 to run. I hope I don't get into furture problems
> > for running on version 10.0.
> > My first surprise, besides the interface, is that it will not see my old
> > vectors from 5.4.
>thanks for your comments!
>    Otto
> > Alejandro
> >   At 11:22 PM 9/5/2005 +0200, you wrote:
> > >On Mon, 5 Sep 2005, Alejandro Hinojosa wrote:
> > >>Dear list,
> > >Dear Alejandro,
> > >>I have Mandrake 10.0 running on my pc box and downloaded the rpm binaries
> > >>for grass 6.0.1 from gdf-hannover.
> > >>Will this version run under Mandrake 10.0?
> > >>I started following the installation order from the readme,
> > >>doing  manually with   rpm -i -v  package.rpm . The first package
> > >>(proj-4) installed without trouble, but  didn't know where it was
> > >>installed. For the second package (gdal-1.3.0-2mdk10.1.i586.rpm) the
> > >>installation  aborted with errors:
> > >>Failed dependecies
> > >>libstdc++.so.6 is needed by gdal-1.3.02mdk10.1
> > >>under /usr/lib there is a libstdc++.so.5  but no libstdc++.so.6,
> > >>Any clues, directions? Do I need the Mandake 10.1 or a  symbolic link
> > >>from libstdc++.so.6 to libstdc++.so.5 will do.
> > >you can try a symbolic link, but I don't think this will work. The
> > >packages are compiled on a mandrake 10.1 and unfortunately not build for
> > >Mandake 10.0 - sorry.
> > >   otto
> > >>Thanks
> > >>Alejandro Hinojosa
> > >>Geology Department ,Earth Sciences Division
> > >>CICESE
> > >>Ensenada, Baja California, Mexico
> > >>Alejandro Hinojosa
