[GRASSLIST:8271] Re: Init.sh problem GRASS5.3
Paul Kelly paul-grass at stjohnspoint.co.uk
Wed Sep 14 07:19:43 EDT 2005
On Wed, 14 Sep 2005, Nagesh Bhatkar wrote:
> Then i copied the executable formed
> ~/grass-5.3.0/dist.i686-pc-linux-gnu/etc/bin/inter/i.rectify
> to my grass bin ~/grass53/bin
That is your problem. It should go in the etc/bin/inter directory. All the
files in bin/ are hard links to etc/front.end so it has been overwritten.
If you copy etc/front.end over from your working installation that may fix
the problem with it being overwritten, or perhaps re-run make install.
Paul
