[GRASSLIST:8329] Output file created after running v.out.ascii  empty - GRASS6.0
 problem
    Nagesh Bhatkar
    bnagesh at nio.org
    Mon Sep 19 08:06:10 EDT 2005
Hi everyone,
I had successfully carried out digitization using GRASS5.3
I have now digitized lines using v.digit in GRASS6.0
v.digit -n  map=zuari_out  bgcmd="d.rast goa-map256out6"
where the backdrop map (goa-map256out6) is geocoded from the xy location.
I get a output vector file,
Upon using v.info  on it , it gives all correct information.
Upon using d.what.vect on it , i get the following output:
map: 'zuari_out'
mapset:'goa'
feature type:'line'
length:21980.862888
It does not display the lat-lon values on the point clicked on the
vector (as it does in GRASS5.3)
Is it a fault in the way i carry out the digitization procedure or is
that the new vector format?
Also when i try to convert it into an ascii file using
v.out.ascii  input=zuari_out output=zuari_out.ascii
the output file produced is empty.
why does this happen?
Regards
Nagesh V Bhatkar
Project Assistant
Physical Oceanography Division
National Institute of Oceanography
India-Goa
Ph.no.: +91 0832 2450306 (Off)
      : +91 0832 2461184 (Res)
Email : bnagesh at nio.org
        nagesh_bhatkar at yahoo.com
