[GRASSLIST:8337] RE: db.execute syntax
Mon Sep 19 12:19:00 EDT 2005
Patton, Eric wrote:
> echo 'UPDATE Opil184a_ship_nav_med_smth SET MOD_60 = 1 WHERE CAT % 60 = 0' | db.execute
Here you've made the opposite mistake, using '=' for an equality check
when it should be '=='.
What does the following do:
echo 'UPDATE Opil184a_ship_nav_med_smth SET MOD_60 = 1 WHERE CAT % 60 == 0' | db.execute
