[GRASSLIST:8370] Re: r.terraflow, or system, out of memory
Cannata, Massimiliano massimiliano.cannata at supsi.ch
Wed Sep 21 13:43:55 EDT 2005
Do you have enough space on your tmp file?
terraflow use temp file that can result quite big...
it happened to me that was the cause of crashing the
command and leaving trash on the tmp dir (i can't remember
now but there's a way to define which dir use as temp)....
Don't know if it is related...
Hope can helps.
Maxi
On Wed, 21 Sep 2005 18:16:45 +0200
  "Michele" <michele.rocc at libero.it> wrote:
> Hi,
> i'm running r.terraflow (grass6.0.1) on a large:
> nsres:      2
> ewres:      2
> rows:       10050
> cols:       7760
> raster and the process seems to stop out of  the blue, i
>know that this module works on the same machine on an
>subset of the data i'm working on.
> Anyway i don't understand if this is an r.terraflow
>problem (I've searched in the bug/whishlist and didn't
>find anything related) or a kernel problem, indeed i
>found in  /var/log/messages
> kernel: __alloc_pages: 0-order allocation failed
>(gfp=0xf0/0)
> Do someone experienced somethig like that and knows how
>to fix?
> Thanks, Michele.
_
Eng. Massimiliano Cannata
Geomoatic Phd student
www.ist.supsi.ch
