[GRASSLIST:610] Re: How do I create a thematic map from a shapefile?
Jesse Hamner jhamner at emory.edu
Thu Apr 6 16:15:51 EDT 2006
On Apr 6, 2006, at 3:16 PM, Thomas Adams wrote:
> List:
> Say I have imported into GRASS 6.1cvs a shapefile consisting of
> basin boundaries. There are NO attributes in the dbf file. What is
> the process by which I thematically map attributes from an ascii
> file that consists of identifiers (that match the IDs of the
> individual basins) and a value (e.g., mean rainfall)? I know this
> is elementary, but I just can not see how to do this in GRASS 6. I
> have looked through all the examples and documentation I can find
> with no luck.
If the basin dbf has no attributes, you'll have to add your basin ID
to the vector coverage first, and then you can merge the rainfall
values with db.execute (or do it outside of GRASS using, say, MySQL).
First add a column in the database for your unique ID. I'd use
db.execute here too, or else do it outside of GRASS in a terminal
window.
To add basin IDs, use the d.what.vect -ef command, clicking through
each basin and assigning the appropriate value to the "BASIN_ID" column.
Last, as noted above, you can then (in MySQL, at least) Left- or
Right-JOIN the tables WHERE index.table1 = index.table2. This type of
JOIN has the added bonus of filling in missing values with NULL, so
you can spot values you might have skipped.
Alternately, you could create a "RAINFALL" field in your coverage dbf
file (here, I'll call it 'tablename') and use
UPDATE tablename SET 'tablename.RAINFALL'= 'othertable.rainfall'
WHERE 'tablename.BASIN_ID' = 'othertable.basin_id';
to merge in the one value; I think that's the right syntax--somebody
tell me if I screwed up.
Jesse
