[GRASSLIST:780] Re: TIN Esri format
M S mseibel at gmail.com
Thu Apr 20 07:23:36 EDT 2006
the node coordinates (X Y Z) could be extracted into a flat file using
UNGENERATETIN.  as far as i know, one would unfortunately need to use their
sw to do this.
On 4/19/06, Hamish <hamish_nospam at yahoo.com> wrote:
> >> I'd like to know if is it possible to import a TIN layer product by
> >Esri > ArcGIS.
> > you could flip the TIN to a GRID and import it that way i presume
> TIN is just a surface of joined nodes so it would probably be more
> accurate to extract the node point data and reinterpolate using
> something better, e.g. v.surf.rst or v.surf.idw.
> Hamish
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20060420/80e696f4/attachment.html
