[GRASSLIST:884] Re: GMT / GRASS use / shp2gmt
Trevor Wiens twiens at interbaun.com
Wed Apr 26 01:12:47 EDT 2006
On Tue, 25 Apr 2006 16:14:35 -0700 (PDT)
Allan Hollander <adh at ice.ucdavis.edu> wrote:
> Trevor,
> I'm a rank beginner at GMT but in my one exercise to date with it I
> learned the following. Mark Fenbers has modified the shp2gmt.c file to
> include the attribute info from the dbf file into the multi-segment
> separator of the psxy input file. His code is given in his message here:
> http://www.mechanik.tu-darmstadt.de/GMT-Help/Archiv/11021.html.
Thanks for the helpful information. I do have a question however.
> The output from his shp2gmt version looks like this for a tiny extract
> from a state map of the US:
> >       Polygon #0      nVertices=17    nParts=1        cat=2   AREA=0  PERIMETER=0.224 STATESP020=3    STATE="Alaska"  STATE_FIPS="02"
> -2.86129e+06    6.01613e+06
> -2.86152e+06    6.01607e+06
> -2.86163e+06    6.01615e+06
> -2.86178e+06    6.01631e+06
> -2.86248e+06    6.01724e+06
> -2.86327e+06    6.01807e+06
> etc.
OK. Got that code and that is working as reported.
> What I can then do is write an awk script to substitute in the correct
> -G and -W plotting parameters depending on the attributes. For instance
> running this bit of awk over the above input file
> {if ($0 ~ /Alaska/) printf "> -G175 -Wblack\n";
> else print;}
You lost me here. In what context am I going to process the file with
awk, in the psxy command line or before hand?
Please provide a slightly more fleshed out example for me to follow.
Thanks in advance.
T
Trevor Wiens
The significant problems that we face cannot be solved at the same
level of thinking we were at when we created them.
(Albert Einstein)
