[GRASSLIST:958] Re: GRASS and vector lines: how can I change the direction of digitized lines?
Otto Dassau dassau at gdf-hannover.de
Fri Apr 28 08:00:35 EDT 2006
Am Freitag, 28. April 2006 13:35 schrieb wqual:
> Hi GRASS list,
> I have two shapefiles which represent the average traffic load for some
> streets in Munich. The traffic is divided into "incoming" and "outgoing"
> traffic.
> What I would like to do: display this map in my mapserver application
> (using ttf-arrow symbols).
> However, mistakes were made during digitizing, thus the direction of the
> lines is wrong (looks like this
> and should be something like
> Therefore my question(s):
> a) is it possible to display these directions within GRASS (I tried to do
> this in ArcView before)
Hi Wolfgang,
the parameter in d.vect is display=dir
e.g.: d.vect roads display=dir,shape
> b) how can I change the direction of the lines in GRASS?
as far as I know you can't, because you define the direction when you digitize
a line from node a ---->----- node b. But you can use columns in the
appendant attribute table to assign different values for each direction (e.g.
speed).
see ->  g.manual v.net.path
afcolumn   Arc forward/both direction(s) cost column
abcolumn   Arc backward direction cost column
regards,
  Otto
> I would be most grateful for some comments on this issue.
> Best regards,
> Wolfgang
