[GRASS-user] Re: changing ps.map resolution
maning sambale emmanuel.sambale at gmail.com
Tue Aug 1 10:59:12 EDT 2006
OK thank you for the info.
maning
On 8/1/06, Glynn Clements <glynn at gclements.plus.com> wrote:
> maning sambale wrote:
> > > Is there a way to increase output resolution of ps.map module? Default
> > > is 72 dpi.
> > I just found it out through the archives.  Its hardcoded in the code.
> > One way to increase reolution is to increase page size.
> Not any more; the downsampling was removed on 2006/02/14. Recent
> versions always output raster maps at the resolution of the current
> region.
| __.-._  |"Ohhh. Great warrior. Wars not make one great." -Yoda     |
| '-._"7' |"Freedom is still the most radical idea of all" -N.Branden|
|  /'.-c  |Linux registered user #402901, http://counter.li.org/     |
|  |  /T  |http://esambale.wikispaces.com|
| _)_/LI  |http://www.geocities.com/esambale/philbiodivmap/philbirds.html   |
