[GRASS-user] integration of sample.c algorithms into r.resample
Dylan Beaudette dylan.beaudette at gmail.com
Wed Aug 9 14:54:52 EDT 2006
On Wednesday 09 August 2006 11:47, Dylan Beaudette wrote:
> Hi,
> I suppose that this is more for the developers...
> I was thinking about integrating the 3 re-sampling algorithms (defined in
> lib/gis/sample.c) into the current r.resample command. It is my
> understanding that r.resample will currently only use the nearest neighbor
> algorithm.
> would anyone else be interested in the addition of bilinear and cubic
> convolution resampling to r.resample ?
> PS: all that this will require is a bit of re-tooling in r.resmaple/main.c
> such that it calls G_get_raster_sample() at each cell in  the input map.
> PSS: thanks to Markus for moving these algorithms out of v.sample, and into
> a library style format.
> Cheers,
A quick follow-up:
in the source for r.resample, it looks like the resampling is done in this
loop:
for (row = 0; row < nrows; row++)
		if (verbose)
			G_percent (row, nrows, 2);
		if (G_get_raster_row (infd, rast, row, data_type) < 0)
			exit(1);
		if (G_put_raster_row (outfd, rast, out_type) < 0)
			exit(1);
		G_mark_raster_cats (rast, ncols, &cats, data_type);
...via the NN style resampling associated with converting between regions of
differing resolution.. (?)
Is this a correct interpretation?
thanks,
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
