[GRASS-user] integration of sample.c algorithms into r.resample
Dylan Beaudette dylan.beaudette at gmail.com
Wed Aug 9 16:12:49 EDT 2006
On Wednesday 09 August 2006 12:42, Glynn Clements wrote:
> Dylan Beaudette wrote:
> > A quick follow-up:
> > in the source for r.resample, it looks like the resampling is done in
> > this loop:
> > for (row = 0; row < nrows; row++)
> > 		if (verbose)
> > 			G_percent (row, nrows, 2);
> > 		if (G_get_raster_row (infd, rast, row, data_type) < 0)
> > 			exit(1);
> > 		if (G_put_raster_row (outfd, rast, out_type) < 0)
> > 			exit(1);
> > 		G_mark_raster_cats (rast, ncols, &cats, data_type);
> > ...via the NN style resampling associated with converting between regions
> > of differing resolution.. (?)
> > Is this a correct interpretation?
> Yes. G_get_raster_row() etc automatically resample the raster data
> (using nearest-neighbour) to match the current region resolution,
> while G_put_raster_row() creates a map which matches the current
> region.
Thanks for the quick reply Glynn.
> If you want any other conversion, you have to keep switching regions,
> so that input maps are read at their native resolution, while output
> maps are written at the desired resolution.
Yikes. That does complicate things quite a bit. I wonder if G_get_raster_row()
could be modified such that it can perform these three resampling strategies
as well. i.e. such that if one wanted a different resampling approach in any
function that uses G_get_raster_row(), it would be possible to specify
bilinear or cubic convolution... Although this might be a monumental task.
> For this reason, you may want to keep your new resampling program
> separate from r.resample, as it will require a fundamentally different
> structure.
Sure. Perhaps a look at r.bilinear would be helpful. What I am envisioning is
something like r.resample / r.bilinear that would integrate the three
methods- as there doesn't appear to be an r.resamp.cubic solution.
Cheers,
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
