[GRASS-user] alter table - sqlite
Markus Neteler neteler at itc.it
Thu Aug 10 12:31:35 EDT 2006
I just tried, no problem... I have sqlite-3.3.4-6 installed.
Do you use a recent 6.1.CVS?
Markus
On Thu, Aug 10, 2006 at 06:09:49PM +0200, Martin Rutzinger wrote:
> hi wolfgang!
> i tried it also without the layer option, but this did not help. i also use
> GRASS 6.1.CVS and SQLITE-CVS.
> may be there is something wrong with SQLITE? which version of SQLITE is
> supported/recommended to use with GRASS?
> but thanks,
> martin.
> Zitat von wqual <wolfgang.qual at gmx.net>:
> > Hi Martin,
> > I am using GRASS 6.1.CVS, and it works with the following command
> > v.db.addcol map=block_extrakt columns="neu INT"
> > I did not specify layer in this command (but when I tried layer=1, I also got
> > the same error message). However, you need not to specify the layer option,
> > as
> > "v.db.addcol adds one or more column(s) to the attribute table connected to a
> > given vector map. It automatically checks the connection for the specified
> > layer." (see g.manual v.db.addcol for example). Additionally, the "layer"-tag
> > needs to be written before the columns-tag.
> > I hope that this might help you.
> > Am Donnerstag 10 August 2006 pH:07:17 nachmittags/abends schrieb Martin
> > Rutzinger:
> > > hi list!
> > > i'm working with sqlite and i want to add a column to the table of
> > > 'vector1'. i tried several possibilities (v.db.addcol, db.execute; double,
> > > real,...) but i got always the same error:
> > > e.g.
> > > v.db.addcol map=vector1 columns="area_size REAL" layer=1
> > > DBMI-SQLite driver error:
> > > Error in sqlite3_prepare():
> > > near "ALTER": syntax error
> > > FEHLER: Error while executing: "ALTER TABLE vector1 ADD COLUMN
> > >         area_size REAL
> > > ERROR: Cannot continue (problem adding column).
> > > e.g.
> > > echo "ALTER TABLE vector1 ADD COLUMN area_size DOUBLE PRECISION" |
> > > db.execute
> > > but: if i use the sqlitebrowser and execute the statement in the 'execute
> > > sql tab' like this, it works(!):
> > > however, i need a solution adding a column using shell scripting & sqlite.
> > > what do i wrong? has anybody had a similar problem?
> > > thanks,
> > > martin
> > > _______________________________________________
> > > grassuser mailing list
> > > grassuser at grass.itc.it
> > > http://grass.itc.it/mailman/listinfo/grassuser
Markus Neteler  <neteler itc it>  http://mpa.itc.it/markus/
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
