[GRASS-user] display error wit latest cvs
Carlos "Guâno" Grohmann carlos.grohmann at gmail.com
Tue Aug 15 15:00:58 EDT 2006
I just compiled the latest cvs, and get an error when I tried to
display a raster. I set the region in the terminal and choose "zoom to
current region". the error msg is this:
Sorry, <map> is not a valid parameter
ERROR: Required parameter <output> not set:
    (Name for output raster map).
Description:
 Outputs basic information about a user-specified raster map layer.
Usage:
 r.info [-rstghp] output=name [--overwrite]
Flags:
  -r   Print range only
  -s   Print raster map resolution (NS-res, EW-res) only
  -t   Print raster map type only
  -g   Print raster map region only
  -h   Print raster history instead of info
  -p   Print raster map timestamp (day.month.year hour:minute:seconds) only
 --o   Force overwrite of output files
Parameters:
  output   Name for output raster map
Description:
Usage:
Flags:
  -r   Print range only
Parameters:
    while executing
"close $rt"
    (procedure "GmRaster::display" line 40)
    invoked from within
"GmRaster::display $node $mod"
    ("raster" arm line 2)
    invoked from within
"switch $type {
        group {
            GmGroup::display $node $mod
		raster {
		labels {
			GmLabels::disp..."
    (procedure "GmTree::display_node" line 7)
    invoked from within
"GmTree::display_node $n $mod"
    (procedure "GmGroup::display" line 25)
    invoked from within
"GmGroup::display "root" $mod"
    (procedure "MapCanvas::runprograms" line 30)
    invoked from within
"MapCanvas::runprograms $mon [expr {$mymodified != 0}]"
    (procedure "MapCanvas::drawmap" line 43)
    invoked from within
"MapCanvas::drawmap $mon"
    (procedure "MapCanvas::display_server" line 9)
    invoked from within
    ("after" script)
thanks all.
              Carlos Henrique Grohmann - Guano
  Geologist M.Sc  - Doctorate Student at IGc-USP - Brazil
Linux User #89721  - carlos dot grohmann at gmail dot com
_________________
"Good morning, doctors. I have taken the liberty of removing Windows
95 from my hard drive."
--The winning entry in a "What were HAL's first words" contest judged
by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
