[GRASS-user] r.watershed in grass 6.1 and 5.4
Hans Hauska haha at kth.se
Wed Aug 16 18:01:49 EDT 2006
I have for a student tried to run r.watershed on a MacBook Pro. The
command was as follows:
/Applications/Grass/grass54.app/Contents/Resources/grass54/etc/water/
ram el="dem25upper at kbackavrinning" t=75 ba="kbbasins" ac="kbacc"
SECTION 1a (of 5): Initiating Memory.
SECTION 1b (of 5): Determining Offmap Flow. Percent Complete:
SECTION 2: A * Search.                      Percent complete:
SECTION 3: Accumulating Surface Flow.       Percent complete:
SECTION 4: Watershed determination.
SECTION 5: Closing Maps.
everything seems to work fine, but When it reaches Section 5 then it
just stands on one point and chews ....
I had it run for over 12 hours, but nothing happened in the final
stage and it never finished.
Has anyone been able to successfully run it?
Is there a special trick? Should I use a Linux version (that is
possible)
I'd appreciate any hints or suggestions on the matter.
Best regards
Hans Hauska
